Ciera2450
Thread starter- Joined
- Apr 8, 2011
- 1,049
Hello,
Just home from the lake and had a suprise when I pulled the boat up the ramp....
When attaching the rear tie downs I noticed the ring anode behind the prop is broken almost exactly in half. One half still attached, the other at the bottom of the lake somewhere. There is a little ding in the prop from where I'm assuming the broken piece hit.
The top bolt is missing, I can see the threads in the housing and half of the threads remaining on the piece of anode. I don't know how the bolt could have fallen out...there isn't really room for it to do so with the line cutter and prop directly aft of the anode.
Did the bolt come loose and cause the anode to break? It was in "good" shape, it wasn't all corroded that I could tell and I boat in freshwater only. (speaking of freshwater, do I want an aluminum anode or zinc???)
Everything still operated fine while out for the past two days. I plan to take the prop off and inspect things further tomorrow morning. Hopefully nothing else was damaged.
Any thoughts guys?
Any thoughts guys?
