kdiddle
Thread starter- Joined
- Mar 22, 2018
- 147
Good afternoon, all. First, a quick backstory - I acquired my grandfather's old 1964 Crosby e/w a 28hp Speeditwin after his passing and set about to cleaning it up and seeing what I had to work with (https://forums.iboats.com/forum/boa...r/10556186-1964-crosby-28hp-speeditwin-rescue). After what I would consider a pretty top to bottom replacement of most everything, I continue to chase my bottom cylinder more or less not running at all.
What I've done on the powerhead so far:
At this point, I'm at a total loss as to what could be my issue. Virtually everthing has been replaced. I even replaced the coil/condenser/points for the lower cylinder today just to make sure there wasn't something wrong with the ones I had (even though I was seeing a spark). I've bypassed the cutout switch and even tried removing both grounding/cutout wires that go to the points just to eliminate them as a possible source.
Basically it will run like a champ on the top cylinder only. You can pull the bottom plug wire off and it makes no difference to how it runs, but I've confirmed that the bottom cylinder is definitely producing a spark. The plug is soaking wet and its puking fuel mix into the run bucket, so I know fuel is getting into the cylinder.
Now the video evidence:
This was from a recent test run in the water
https://youtu.be/q3Md7REdlWU
Here is proof that the bottom cylinder is getting fire, and putting back on on spark plug makes no difference
https://youtu.be/7RSLPyz9fMY
Here is it 'running' until I pull the top plug
https://youtu.be/_wp6u-UohtA
Here is playing around with the cutout/grounding wires trying to see if anything makes a difference:
https://youtu.be/0mOQyL-qcV0
I have put a small fortune into trying to get this old girl running, and the only reason I've done so is that it belonged to my granddad and I'd like to see her on the water again. If anyone has ANY theories, I'd love to hear them, as I'm about at my wits end. I cannot fathom for the life of me what's going on here. Thanks for taking the time to read my ramblings...and thanks in advance for any input you guys have.
- Bored .040 over and replaced pistons/rings
- Rebuilt carb with all new parts/seals
- Replaced both coils/condensers/points and set gap to .020
- Replaced spark plug wires/boots/plugs
- Replaced fuel pump
- Replaced all rubber hoses
- Replaced all engine gaskets (intake/exhaust/leaf cover/etc) along with rubber o-rings at the crank ends
