Horigan
- Joined
- Jun 12, 2016
- 756
I had an issue earlier this year where I lost a rear prop on one of my 290 DP drives due to apparent insufficient torque on the prop cone and center bolt. I had used a Volvo prop removal/install tool and thought I had pretty good torque on the cone and center bolt. I acquired another rear prop and a used cone with center bolt. This particular center bolt took a 12mm socket to tighten. (The other side has a 13mm socket bolt.) During prop installation from the swim deck (boat in the slip) I felt the 12mm socket slip during torquing. I assumed I had rounded the bolt head corners and ordered a 13mm head center bolt for the next anode change. I did that anode change yesterday and discovered that I had actually sheared off the center bolt. It is flush with the end of the inner/rear prop shaft.
A couple of questions:
What approximate torque are people using to install the rear prop, both for the cone and the center bolt? I see little reference to prop nut torque in the 290 manual, except where it describes drilling the center shaft using the tool referenced below and torquing the cone on to 81 ft-lbs (center bolt 16 ft-lbs). That torque level isn't really possible with the short Volvo prop tool.
I see there is a Volvo tool 885149 that's a drill jig to drill a hole down the center of single prop 290 drive shaft to enable the installation of the center bolt. Does anyone know if this tool will work on the inner/rear prop shaft of a 290 DP? I was going to fashion my own tool to drill and remove the sheared bolt, but this tool may be easier.
