Re: 2C mower runns dies runns dies (FIXED!!)
The electronic coil on that engine either works or it doesn't.<br />If you haven't cleaned the carb, do so, and add anew piece of fuel line...you may have a flapper inside the line that is restricting flow.<br />It starts and burns what's in the bowl, but is just a trickle in the line allowing start-up after it dies. A plugged fuel filter will show the same symptoms....<br />another thought is water in the system...If you looosen the bowl-nut and catch what drains out in a baby-food jar you can tell...It will suck it up the nozzle, die, the water drains back into the bowl, next start may have a bit of fuel until it pulls water again, dies, etc, etc...<br />You can pour about 2 ozs. of "Heet" in the red bottle in to help if it's water.<br />Sometimes it's tuff to get every bit of fluid out of the tank...
