Re: 2hp help
wow quick reply, while browsing more i found an interesting way to tell,, the word " introduces, using 1,2,3 etc under each letter tells you the yr. Course you probably already knew this. Just got it and pulled the rope while having the plug unscrewed to check for spark. None, I suspect i should start with a new plug? Already drained the gas. What about the impeller?
tks
