have a 1980 2 hp Johnson, runs fine except when I put the lever to full throttle and let go, within about 5 seconds it works its way back to about 1/2 to 3/5 throttle, the bolt holding the linkage is as tight as it can go, any suggestions? Thanks
another words--turn it clockwise a quarter turn and see if that gives you enough tension, then another quarter turn if needed
I have the answer you seek! I have two of these suckers and know why you are having this problem. Ok under the flywheel there is a plate that the magneto points and all that stuff is mounted to. If you look close to the shaft you will see a plastic collar and a screw that is turnable with a flat head screw driver. Turn that screw in a little and you will solve your problem
