2nd battery size
fishfeatures
I am going to add a second battery to my boat and also a battery switch so i can use/recharge one or both. I have a 60hp 1990 johnson and am a bit tight on space and want to keep the weight down at the stern. What is the smallest size battery I can get away with for starting the boat? would say a motorcycle battery start it?
My main battery is a deep cycle and I would like to use this for the ancillaries (sonar, 12v, pumps, etc)
Don S
Re: 2nd battery size
No, you don't want a motorcycle battery. That size motor a battery with a minimum of around 350 CCA (Cold Cranking Amps) is typically recommended.
A typical group 24 battery will normally fit. Size 7" x 11" by 9" high
If you want a smaller case, you might check the auto parts stores batteries and see how small one with 350 CCA is.
fishfeatures
Ok thanks for that info Don, I'll check around and see if i can get the smallest 350 CCA one
