LilRedNeckGirl
Thread starter- Joined
- Jan 25, 2010
- 184
basics, 1985 3.0 in a wellcraft 248 sportsman, running twin setup.
a few years back, we bought this boat and did nearly a complete redo. now going on two years no major issues. spring pre season maintanace has us under the engine hatch pokin around and i noticed something.
the issue.
the carbs both have the clear ? vapor tube ? that runs from the carb, down to a fitting on the fuel pump.
this tube has begun to get a 'green' buildup in it. one engine has this buildup at the fuel pump end of the tube, the other has it up near the carb.
what is the green stuff?
is it normal or is there an underlying issue?
does this fall into the ' just replace the tube every year' catagory?
now, additional info, when we bought the boat, these tubes were clogged nearly solid with this greenish gunk. { it appeared at that time, to be an oily gunk, with a consistancy of light grease.} We had both carbs rebuilt by our mechanic, we installed two new fuel pumps, { the old pumps worked, but had set for 8 years }, and we replaced the clear tubes with new.
The carbs / engines have been flawless in preformance and dependability, start every time, never miss a beat. We run water seperators on each seperate fuel line, have a clear inline filter after the pump / before the carb, @ a window into the fuel system. the recent seasonal change showed only normal & reasonable contamination in the filters.
Fuel is always a premium blend of mid grade without ethanol.
Winter storage is always with a fuel storage addative, and a sea foam addative is run as maintanace a few times during the season.
oil is changed 2 times a year and always kept up to level and clean.
typical engine run time is at a comfortable 3000 RPM cruise, running about 45 minutes. very little idle time is typical.
engines are always brought up to about 160 degrees, normal operating temp, before we start out each morning.
Sooo, any ideas on the green stuff, causes, need to worry, or something that needs fixin?
the issue.
