3.0 compression check tell me I have hope
thejeep007
Well boats be running rough this year and last I guess. Number 4 wasn't kicking had spark so ran a compressiontest. Hope the tool was little off. Readings in psi from 1_4. 70, 70, 90, 0. Gunna pull the head and see what's goin on. Hope I head gasket will make her happy enough. Any thoughts would be appreciated. It's a 89 3.0 mercruiser.
bonzoscott
Re: 3.0 compression check tell me I have hope
I would think there would be "some" compression even with a bad head gasket. More likely stuck open valve/s. Pull valve cover and verify all are moving / working while cranking before pulling head. You may have to pull head and repair a bad valve anyway, but easy enough to check.
thejeep007
Good thinking. Any thoughts on the other cylinder compressions?
PatrickBoyle
If those compression numbers are correct you've got some serious issues. Even if they're wrong you've got some serious issues in #4. Like bonzo said, it's either a damaged valve or a hole in the piston. Good luck, let us know what you find.
aerobat
did you apllied full throttle on the compression check ?
thejeep007
Negative. Closed throttle on test. Gunna pull the valve coverin a few, iI'll post what I find. Thanks
PatrickBoyle
The throttle plate thing is rubbish. If the engine can get enough air to idle with the throttle plate closed, it's getting enough air for a proper compression test. The most important thing that a lot of folks miss, is to remove all of the spark plugs when doing the test.
thejeep007
1369848465884.jpgGot it off. Lookin around see what's goin on. Here is cylinder 4
Don S
No, it's not rubbish, and it's not about the air. When you crank the engine with the throttle closed, it will suck fuel out of the carb and give possibly incorrect readings.
That's why on EFI engines you disable the ignition and the fuel pumps.
Idlespeedonly
Looks like a lot of pitting on the intake valve. Do the others look the same?
thejeep007
More cylinder 4
PatrickBoyle
Does piston 4 move normally (as in, in sync with cylinder #2 with full stroke) when you turn the crank? It may be a reflection, but those wear marks on the bore look odd.
thejeep007
More cylinder 4. That's bottom of head gasket between 3-4
Idlespeedonly
Lots of water in the cylinders at some point.
thejeep007
Seems to move fine art with the rest of em....
Don S
You have been getting water in it for some time. The pistons have all been steam cleaned. I would bet you had a valve stuck open from rust that caused the 0 compression reason.
thejeep007
Definitely water in there at some point. Pervious owner maybe.. Not sure where to go from here....
Don S
Had you not pulled the head, you could have done some other testing to find out where the problem is. Now your kind of stuck looking for obvious things you can see.
thejeep007
Don't have much time off from work so jumped in. Getting a spring compressor now let you know what's behind it. Thanks fie
