3.0 compression check tell me I have hope
thejeep007
Re: 3.0 compression check tell me I have hope
I am with the dirty budget post haha. Got a used head from a friend for. Hundred. If that doesn't do it he said take the whole thing. Maybe some winter fun either way. This isn't a race boat guys, low compression from worn cylinder will get me fishing and always have enough beers to wait for a tow
aerobat
put the head in and go for fish , beer and girls. report how the engine runs.
i checked the compression for a friend on a tired 170aq grandpa in a birchwood 22 footer. 2 cylinders are 50 psi and the rest below 90. guess what - the grandpa puts the boat on glide and the girls onboard have fun. beer included.
happy boating...
thejeep007
Should know tomorrow evening. Hope a few of you guys areppulling for me...
Cptkid570
Ensign
Let us know the result. I see 3.0 motors on craigslist all the time. If you like the boat, I've seen remanufactured 3.0 longblocks for $1500 at remanufactured.com (I don't know anything about them, I just saw on another post one time that they sold reman 3.0s).
thejeep007
Put the other head on still nothing in number 4. Guess I'll be Rollin on 3 cylinders till I get that other engine.... Anything I should check before buttoning it up or just no seal on piston....
aerobat
ouch... so i was too optimistic for you ... but when you say "nothing" you mean still zero ?
can you post a close up picture of the number 4 piston ? it does not seem blown from the other pictures, low(er) compression is one thing, but how you get zero ? broken compression ring ?
thejeep007
Posted close ups earlier. Can't get em up again
Don S
Have you checked other cylinders to see if they have compression? Would sure be bad to have checked only number 4 and find the gauge died after checking #3 the first time.
thejeep007
Rechecked number 2 have 60 can get a used motor that the head came off, just need to pull it and swap some parts over like timing cover. So could be worse. Just frustrating as hell throwing the rest together and goin out tomorrow. Think all the damage is done... Fixing the riser leak though... Any mor input appreciated. Thanks for laying off the I told you so
Don S
Why are you putting it back together, one cylinder with 0 compression and the others in the 60 and 70 range ???????
That engine is junk.
roseran
your hydraulic lifter is stuck and won't let the valve close.
thejeep007
Lifters are seating properly. Got the new to me motor and just pulled the one from the boat. Should be at a driveway start level by Monday. With the motor out is there anything you guys can think to do now that can save me aggravation in the future? Oh ya when I pulled the head off this time with different head different manifold had water on top of the piston.... A crack in the cylinder I can't see?
fishrdan
From post #24, first page (couldn't get pics to post in my reply...........)
Where is the water in the mainfold's intake runners coming from?
I'd dry the manifold off and fill the waterjacket with acetone, to see if there is an internal leak in the manifold. Cracked manifold letting water into intake runners?
Cptkid570
Ensign
while the engine is out, I would check the timing chain cover (timing gears on this engine if I remember right).. anyway, that cover has tendencies to rust out and it is easier to change while the engine is out of the boat.
thejeep007
Ya the timing cover on the motor I pulled is goin on the new to me motor. Replaced it last year. Can'twait to to drill and tap aanother crank to get the pulley back on too. I used a different manifold with the different head. Why use acetone to check it? Can't complain about pulling the 3.0. Did notice the pinion seal leaking gear oil into the bellow but will hit that once I have a functioning motor.....
ajax5240
Bent valve stem? Or rusted in place during compression test. Like Don said, too bad you pulled the head as the results from a cylinder leakage test would have saved you a lot of detective work. Put the valves in the head, turn it upside down so the combustion chamber faces up. Pour water in the combustion chamber and see if water leaks past either of the valves. Obviously you need a spark plug in too.
With no catastrophic failure from your pictures I would wager that a mistake was made in your reading of cyl 4. Even a bent valve and a small hole in a piston will give you a little compression. Either your helper had their finger on the pressure relief button or you didn't crank it a full cycle to build compression.
How do the cylinder walls look in the #4 hole?
thejeep007
Looks like the compression culprit...
ricohman
That vertical gouge looks like a busted compression ring.
At the minimum you need to re-ring and have that head rebuilt. The used motor out of a rotten boat is a good idea.
Yup.
