capecodtodd
Thread starter- Joined
- Aug 11, 2010
- 128
Big trouble on little engine. My 1998 3.0 mercruiser will not start. Due to rough running which has been a problem the few times I have had the boat out this year, this morning I went to check the timing and it was way off. I followed the manual on how to check it and turned the distributor to were it should be and the motor stalled out. I put it back to where it was and it started fine but was still running rough. I have a suspicion that the plug wires are not on correct. I have looked at the order in the manual and here online and it seems to be a common issue. I could not find the order stamped on the block which may be different than what the cover and manual say. Where is that located on the block?
The top of my spark arrestor cover has the order typed there and it corresponds to the manual is that ok? It was running with this order but rough.
When the wires get put on the cap where am I supposed to start with #1 wire? I am assuming the distributor goes clockwise for that is the way the arrow in the manual is pointing and that is the way I put the wires on starting with #1. Is there a mark on the cap or distributor that tells me where to start on the cap with plug wire #1 ??
The boat hadn't been used in 2 seasons, so new gas and filter, new fluids, new plugs, wires, cap, rotor, thermostat, new water pump the old was leaking and rotted out a spot on front seal cover so it was dribbling oil so that is new as well. The rough running is not new this year.
Any ideas? Thanks in advance.
