3.0 GS PWTR,SQUEALING NOISE COMING FROM MY CIRCULATION PUMP BELT
  • I Don't Know
    Votes: 0 0.0%
  • I Don't Know
    Votes: 0 0.0%
  • Total voters
  • Poll closed .
CROWE
3.0 GS PWTR, I HAD THIS SQUEALING NOISE COMING FROM MY CIRCULATION PUMP BELT RUNNING TO ALTERNATOR IT GOES AWAY AFTER 10 SEC.AFTER STARTING, I REPLACE THE PUMP ABOUT A YEAR AGO,I CAN RUN THE ENGINE WITHOUT THE ALT. BELT AND SQUEALING GOES AWAY,I REPLACE THE BELT AND ALT. AND STILL HAVE THE SQUEALING, I REMOVED PULLEY FROM CIRCULATION PUMP INSPECTED ON PROBLEMS PUMP TURNS FREE WITH NO LEAKS, NO RUB MARKS, ON PULLEY.
first, why do you have a pole question?
second, why do you type in all caps? no need to shout
your alternator could be going bad (bad bearings), your belt could be loose.
GA_Boater
first, why do you have a pole question? :eyebrows:
second, why do you type in all caps? no need to shout Good Question
What are you working on? Volvo-Penta isn't it? This should be moved to the right forum, Monterey boats is the wrong place for motor help.
