MyLord
Thread starter- Joined
- May 27, 2020
- 29
Hi , after not using the boat for a while I wanted to turn the engine over. The engine does not turn and seems stuck rock solid. I removed the engine valve cover but everything looks fine oily , no rust, the engine oil is clean and full. The boat was fogged when put away. I put MMO into the cylinders but this has not helped after 2 weeks. I removed the starter but the flywheel teeth do not move and I don't want to hit them too hard.... is there a bar that could move them while still in the boat? I have a chain wrench but am not sure about how or if I should try using it.
Could the valve inside the cylinder be rusted up? What should be my course of action?
thanks
thanks
