YahooMarine
Thread starter- Joined
- Jun 28, 2011
- 9
Greetings. I have a 2009 Chaparral with the 3 liter engine. Ran well for many years but this spring on startup the carb is leaking gasoline. The original carb was a Demon 2 bbl but it was recalled and replaced in 2011 with a Holley. No issues before. Always have had a canister fuel/water separator and never ran it in saltwater.
The problem is Volvo no longer has this carb available. The part # is good but the carb is on a backorder with no date for getting one.
I called Holley's tech help line and they could not identify it ... list # 2570 is stamped on the choke tower. Holley says it was likely a special run for the engine. VP stopped making the carbureted 3.0 liter after 2010.
A rebuild parts kit was identified by # to me by the dealer and I can get one from them or Amazon or eBay.
The question: Has anyone needed and found a replacement carb for this era of engine? If the issue is as simple as a bad gasket or seal the kit will likely solve it. However, if there is internal corrosion or a cracked casting I will need a new carb. Holley suggested a new 2300 model but it is not an exact swap.
I will get into the carb tomorrow to see what the issue is.
In the meantime, any advice or guidance would be appreciated as I am dead in the water and can not get good advice from the dealer, VP or Holley. This marine carb is a mystery.
Thanks, Rich
Thanks, Rich
