Scott06
- Joined
- Apr 20, 2014
- 6,775
All looks like it's heading in the right direction. After you get the idle mixture screws and speed set in the water in drive, if you are fouling the plugs might check the fuel pressure is 4-7 psi. If it is more it can overcome the needle and seat and run rich. While it's sounds like your issue was intermittent, bear in mind that the 3.0 is not known as the smoothest running engine. Had one for 20 years, very reliable, just not smooth at idle
