3.0 mercuiser wierd noise bogging
tbone999
Hey on the water as we speak gonna limp home just sitting beside my crab trap waiting for a soak, wierd noise was doing 26mph at 3800 rpm all was fine set trap and dogged a bit the did this any ideas https://youtu.be/HgyorjUhd0A
Does it do this every time it is accelerated? If you keep it at higher rpm does it continue to bog, but also guessing since your limping home may not want to find out right now
tbone999
Little update running fine when i very slowly accelerate only seems to happen when i get on it, could this be belt slipping??
Don't think so right now with the motor shaking like it was, I'm thinking fuel issue. In most cases a belt would start to squeal
tbone999
Ok ill check the filter when i get home i just thought it looked like it was slipping in the video
Ayuh,.... Sounds like detonation, probably from a lean condition,.....
