- Joined
- Jul 23, 2011
- 53,258
They are 6-cylinder dizzys. However you could pull the shaft from your current dizzy
I believe it does. however I would want to visit NAPA or your local FLAPS and verify prior.The 4cyl cap would fit the 6cyl body if I swapped the shaft?
Dependss. If you can rebuild the distributor which isn't hard if the shaft is not buggered and the advance plate is not corded then get a good core and rebuild it. If you cant get a decent core get a rebuilt one. You still need to reuse your 4 cylinder shaft for the rubbing block no ? Might be worth finding out if that is in good shape before making a decision on a pathSo the 6cyl ones are available everywhere for not a lot of money. I wonder if there is a benefit to getting a rebuilt vs used distributor
I emailed him but haven’t heard anythingDid you reach out to Tom? he usually answers back within a day.
I want electronic or at least solid state ignition. I know the points are perfectly fine in general, but i don’t want point bounce/ inaccuracy under boost. So a pertronix kit is something I would install in a points dizzy.Dependss. If you can rebuild the distributor which isn't hard if the shaft is not buggered and the advance plate is not corded then get a good core and rebuild it. If you cant get a decent core get a rebuilt one. You still need to reuse your 4 cylinder shaft for the rubbing block no ? Might be worth finding out if that is in good shape before making a decision on a path
Gear anything back?I emailed him but haven’t heard anything
I actually haven’t. I got side tracked. I’ll have to try again. I’ve been doing some bodywork on the cab latelyGear anything back?
