canadiancadorette
Thread starter- Joined
- Sep 1, 2007
- 6
Hello, just wondering if anyone has had the same thing as me,I am having a chirpping noise similar to a belt noise only under load or if you give it a quick rev.I changed the belts ,no help,changed the manifold gasket,it was leaking some and I resufaced the manifold as well to clean it up.I ran it without any belts on it for a few seconds,no difference,changed the timing slightly,no improvement ,premium gas in it too.Last thing I did was pull off each plug wire and start it ,it doesn't do it with the #1 off but will with each of the others off,so this is telling me that #1 cylinder is the problem,right??Now what is the problem ,maybe a bad lifter or weak lifter?I haven't checked the compression yet but it does run great only has 300hrs on it,it's an 89.Any help would be greatly appreciated thanks.
