3.0 OMC Trim wont raise up
branden0502
Hey everybody
I put my boat in the water today, lowered the trim, went out on the water for awhile. When I put the boat back on the trailer, I push the trim up button, and I hear a click, from the pump in the back, but nothing happens. Down works, I can still hear the pump running, but up just clicks once and then nothing. It worked just fine yesterday.
Thanks for the help
Howard Sterndrive
Re: 3.0 OMC Trim wont raise up
sounds like a bad connection. time to check, clean and tighten wiring.
jerryjerry05
Once you clean the connectios(howard) and get it working.
The trim raams on the drive,lube them with WD-40 or any oil.They dry out and need lube.
