3.0 tap/knock
Mskeels
Hello everyone. I rebuilt my 3.0 Merc and have some sort of tap/knock around piston no3. Any advise and direction in solving. I have no interest in taking it to a shop as it’s a hobby and like to learn!
I couldn’t notice anything moving in the bottom end.
TIA
79B5240B-27C6-4A57-8126-3AC9D4FD0555.jpegCEED7AC5-A631-4F34-BBE1-F0591FDAD74B.jpeg7DB67EA2-B8C4-4FED-A3D2-2E4D20A5E174.jpeg
View attachment IMG_0370.MOV
dubs283
First "distributorless" 3.0L I've ever seen, not many out there
Sounds slow enough to be a valve/lifter issue
Would recommend a mechanic's stethoscope, cylinder drop test, running without the belt, removing the drive and running the engine, try running on the water under a load, etc....
Alumarine
If you suspect 3 have you tried backing off and then tightening the lifters for 3 to see if the sound changes?
Did you plasti-gauge the rod bearings?
Mskeels
Thanks bud. Removed the coupler so no drive and used a stethoscope seams like it’s around the no3 cam area. Really cant see anything
Mskeels
Yep tried the backing off the lifters. Didn’t use plastic gauge on bearings as new and crank was done
Scott06
I would be checking the clearances and also wrist pin. doesnt sound like valvetrain to me but could be. Even if it was machined check them always. I have had to take rods back that were resized wrong.
was it bored? I had an old volvo that on real cold starts would have some piston slap until it warmed up which sounded similar. This was due to forged piston cold wall clearance being more than typical cast piston.
Mskeels
Thanks I’ll look into this. Do the conrod widths look large?
dave8311
Sounds like a rod knock to me.
You didn't check bearing clearances?
Mskeels
I would check the side clearance on the con rods vs spec. In your first post the main bearing cap is off was there scoring on the crank?
you said crank was done by whom ?
shop did the crank. well know local guy. no scoring on crank bud
Scott06
Its the side clearance on con rods that look big?
Can tell from the keyboard. It’s making noise so you need to go through and measure all the clearances vs spec. If you don’t have the mI do eters would take it to some one who does
dave8311
That pic before or after you ran it? Wrong bearing clearance will mess up a newly machined journal.
Are those rods not the ones that came out of that block, originally?
