3.0 Volvo Timing Marks ??
dollarart
I have a 2003 3.0 Volvo GSP-3. I bought the boat used and have the list of problems !!!! One being the distributer seized. I installed a new distributer and got the boat running "by ear". I want to time it....I bought the jumper plug # 885163-6 ....I have the mark on the flywheel marked in white and am ready to go !!! EXCEPT, I can't see any numbers on the timing plate on the motor !!! It has 5 notches and none are deeper than the others so I have no idea which is top dead center. I know the basic timing on this motor is 2 degrees ATDC....I just don't know what notch to use !!! It seems to me that I could be off as much as 10 degrees either way if I guess wrong.
I have a photo of the plate from the seloc manual and I can't really read it either !! I am attaching the photo to this post with the hopes that someone can describe which notch is TDC and I will go ahead with timing my engine.
Thank you....I recently loined this forum and it has been a tremendous help in getting my boat running !!
dollarart
Re: 3.0 Volvo Timing Marks ??
Whooops !!! The Motor is a 3.0 GSP-C
Thanks, Art
dollarart
Hi,
I have continued to try to come up with the correct spot on the timing plate for my motor. I have it timed by ear and seems to be running ok but I would like to actually find the correct mark and know it is set to factory specs !!!
If anyone can come up with this info, please reply.
Thanks, Art
Robj
I do not know this motor, but since no one else is responding, I will give it a try. Pull out no. 1 plug and rotate the engine until no.1 cylinder is at the top of the compression stroke. Then look at where your timing mark is. That should be 0 degrees. Time it with the light as you would normally do. Timing it by ear can be dangerous and cause engine damage if you are off. Use a light. My guess is that each of the points is 2 degrees. You can also figure that out if you want with basic math.
Have a great day,
Rob.
