3.0GS PLKD 1997 Milky Oil Update
Regal1700
Hi,
I Overheated and had Milky oil The Engine did not lockup or Hydrolock.
So Far I did the following:
1. Changed Oil 2 times and after running it on muffs the oil became Milky.
2 Tried to perform a compression test but found water in cylinders.
3. Removed Head and exhaust manifold. Sending the Head out to get checked out.
4. Ordered Entire Gasket Kit for Upper motor.
5. The block was fine with no cracks or issues.
6. Exhaust Manaifold was fine too.
Am I missing anything Gaskets looked fine but I could see some deteriation between gasket on Cylinders. I suspect thats how the water was gettin in? But Im no expert.
Thanks
Also I ordered a new thermostat and I see it in the Housing but dont have any Idea how to remove it to chage it.
Thanks
Regal1700
Re: 3.0GS PLKD 1997 Milky Oil Update
Bill,
We found water on all the Pistons.
R
