Scott06
- Joined
- Apr 20, 2014
- 7,619
I would look in the system like the power steering cooler that this sand is not still clogging Something. I say this because if you use a OEM mercruiser or quicksilver impeller it should be lasting longer, unless it was sitting for years on the parts shelf.Well I did suck up a bit of sand but that wasn't last year, it was the year before, but of course its going to bring the pump components that bit closer to the end of their life.
I honestly don't know why I didn't change the damned thing when it was out of the water. I even grabbed a box from a shelf in my garage which I thought contained an oil filter and took it to the boat. When I got there, it was an impeller - the universe trying to tell me something.
Yes you have to wonder about the wisdom of a design where a consumable part which needs changing at regular intervals is buried deep in the works, and inaccessible when the boat is in the water. I suppose we should be grateful Mercruiser didn't put the oil filter somewhere inside the sump.
also if sand got in there there may be scoring of the housing.
i have changed perfectly working 6-10 year old merc impellers that are in perfect condition. Everyone complains about the alpha one impeller location but there is no free lunch. If you look at where a lot of the engine driven pumps are they can be a pain to get to and you still need to block the water flow off if it is in the water. you also have a very easy engine compartment with a 3.0 i always enjoyed working on mine.
personally i am a fan of the alpha design, simple, inexpensive (as far as boats go…) and durable.
in my opinion stop screwing around , bite the bullet and fix it correct so you can enjoy a beer on the water… also check that you have no blockages from pulling in sand and look up in the water connection in drive upper. If you pulled enough sand to notice You may have interrupted water flow and melted the orings or plastic parts and impeller is fine just leaking water down stream.
how big is the Wannsee? I visited Chimsee by Chemung in 2013 absolutely pristine and gorgeous
