3.0L Mechanical Fuel Pump Install
tgell001
So does the 3.0L actuate the fuel pump with a push rod that is driven by the cam? And if so how do you orient this correctly during the install? I did not note this when I removed it last year and is it possible that it fell out and is in the oil sump? Hoping I didn't make a rookie mistake. I don't see that part (push rod or actuator) anywhere on any of the exploded views so I don't think its that style. But, I want to make sure. Also, the new pump came with a spacer. I don't think I removed that but can someone confirm... (GLP-J)
tgell001
Its not that style. I reached my finger into the hole and felt the lobe on the can or crank whichever it is. Installed pump and works great
