jr1017
Thread starter- Joined
- Aug 24, 2008
- 17
1988 3.0L Mercruiser. Has always purred like a kitten since owned which has been a little over 3 years now. It was tuned right before I bought the boat (new plugs, wires, cap, rotor, condensor, points, etc) and I've just pretty much changed the oil and lower gear oil each year. The boat does not see alot of use each year, in fact I've used the boat maybe 6 to 8 times per year it has been in the water except for this year which to date I've only had in the water 2 times so far.
Problem: I brought the boat home and put the muffs on to fire up and run for a bit as I usually do before I leave for the lake. Ran like usually, purred at idle and everything seemed to be fine. Got to the lake to launch and I admit I was in a hurry and not thinking and launched without putting the drain plug in first. Once boat was in the water I got in and started it up. Idled for about a minute and then put into reverse to back off the trailer. When put into reverse and started backing, the motor died. I restarted the engine and as soon as I put into reverse it stalled again. Then it dawned on me what I had forgotten to do. Got the boat pulled back up the ramp some and allowed the water to drain out. It was still somewhat dark out and I have no idea how high the water got inside the engine compartment. (it didn't seem like the back of the boat was anywhere near sinking or that bad) It did take a few minutes for the water to drain back out of the boat. Me not knowing what I was doing, put the plug in after the water drained out and backed the boat back into the water and tried to start. It was a bit difficult, but it did fire up but I had to keep the rpms at 1800 or above. Anything less and it would stall out. Someone at the ramp told me that I needed to just let everything air out and dry before it would run properly again. (Something had gotten wet that is not supposed to) Brought the boat back home and parked. Someone told me to check the distributer for water or moisture, so after 3 weeks of sitting, I brought the boat home and checked the distrubitor. It was dry inside. I started and it fired up but same as before, I have to keep the rpms at 1800 or above to keep the engine running on its own. Anything less and the rpms gradually slow until the engine stops running. The oil looks clean and no signs of water in that.
I don't have a service manual for this yet (maybe I should buy one), but does anyone out there have any advice or some steps as to what the next thing or things I should start to check to figure this out? The gas tank had just been topped out and the gas is good, and the gas should still be good shouldn't it? Any advice is greatly appreciated and thanks in advance...
