havoc_squad
- Joined
- Mar 5, 2011
- 739
The first lake test after de-winterizing my boat 1.5 months ago, my idle is mostly crap at load. It gets worse as the longer you stay at idle under load, which is making me suspect flooding at idle.
Also, I believe after a run at speed, it seems to idle slightly better at load until you get past the 2 minutes or so, then the idle starts to break down slowly over time.
The venturis are NOT leaking, I checked that myself.
Last year I installed a clean remanufactured mercarb of the exact model. It was adjusted properly and the boat could idle in all aspects fine.
Do I say bad gas? No, its 1 year or less old. I don't suspect water intrusion since its 100% non-ethanol gas.
Do I say trash in carb? Possible but not likely, have water seperating filter, the fuel pump's stone filter, and the filter in the carb inlet.
That leads me to suspect the fuel got varnished or non-trash based obstruction in the carb.
On most carbs, how much removal does the Mercarb generally require to clean out idle passages 100%?
