3.0L Mercruiser noise vibration
Quinnfloor
I have a 2000 Larson 176 sei bowrider with a 3.0 mercruiser. I seems to have a vibration like a motor mount worn or something. It has different vibrations at different RPM's. When driving at low rpm and I turn the wheel which puts pressure on the drive train in seems to go away. The warmer and smoother the engine runs the less I hear it. HELP !!!
Don S
Re: 3.0L Mercruiser noise vibration
Pull the drive and check the ujoints and gimbal bearing, also make sure there is no water in the bellows and check the engine alignment.
Haut Medoc
No, that is pretty simple.....
If you have not had your drive off in awhile, you need to lube the ujoints anyway......;)
tommays
It is as simple as DIY on a boat gets :D 6 nuts and some c-clips
Now if you find water when you pull the drive then simple is all used up:eek:
Tommays
