Hey guys,
Thought I'd throw this out there. I am having some cold start issues. It is a 84' or 85' mercruiser 140 serial number 6920111 and mercarb 1389-8490 which is a rochester I believe. The issue is with a cold start on the trailer in the water. It fires right up, with a throttle prime and throttled about 1/4 way. The rpms come up to about 1200 -1500 and I let it idle there for 2 minutes or so. I then try to go to neutral and it dies. It takes about 10 to 15 minutes to get the engine warmed up enough to get it into neutal and to put it in gear to get off trailer. I do not believe it should take that much time but i dunno. Once the engine is warm it runs great and I can stop and shut engine off and such and runs great. Its just the cold start.
I have set the idle around 700 because it seems to not like going down much lower. The timing is set at 6 BT and such, like i said it runs great when warm.
It has new fuel pump, new spark plugs, rebuild carb, new electric choke, electronic ignition.
Any suggestions on why it would take so long for the engine to warm up or is something else not set up right?
Thanks for your input and help!
