3.0L Mercruiser
BigRedTSI
I just bought a boat with a cracked block. Its got a 3.0 mercruiser and I need a block for it. Where can I find one?
Fishermark
Re: 3.0L Mercruiser
Well, forget trying to find an automotive replacement. Check Craigslist, ebay, etc for another 3 liter marine engine.
Oh yeah, welcome to the forum! :)
Don S
Re: 3.0L Mercruiser
BigRed, you have a PM,
Welcome to iboats.
BigRedTSI
Re: 3.0L Mercruiser
Thanks for the welcome. I am on many car forums as well as Salt water fish forums but this is my first boat forum. So there is no possibility of boring a 2.5 and using the 3.0 crank and pistons. The engine that was in the boat was not winterized and cracked. It is in a 99 Mirada. Also I was curious on more info on Miradas as I can't seem to find any.
Bt Doctur
Re: 3.0L Mercruiser
If your close to nj you can have the block in my garage.
block was supposed to be good, never worked on it , just been sitting taking up space.
BigRedTSI
Re: 3.0L Mercruiser
Where in NJ I am actually driving to NYC tomorrow(monday)? I am in western NY.
Don S
Re: 3.0L Mercruiser
Do your buisness in a PM or email guys.
BigRedTSI
Re: 3.0L Mercruiser
Could I use a 3.0 from any year or do I have to use a certain one?
Fishermark
Re: 3.0L Mercruiser
If I'm not mistaken, all the 3.0 liter blocks are the same - just be sure to transfer the "stuff" from your current engine to the new block and you should be fine.
BigRedTSI
Re: 3.0L Mercruiser
Is there a place I can look to find out what years had what blocks and if they changed them from year to year? I found a good deal on a longblock from a 94 searay and my boat is a 99 Marada If that motor would work I could pick it up for a good price and be up and running in no time.
Re: 3.0L Mercruiser
Ayuh,...
Those vintages use the Flywheel mounted couplers,...
At the very Worst,....
You'll need the Flywheel from the New motor with it...
BigRedTSI
Re: 3.0L Mercruiser
Ok so i could just take the flywheel off the motor in my boat and be ok. I figured that but wasn't sure if they had made any changes to the crank. But from what I am finding in my research they are all the same.
