I think I overtightened a rocker or tightened it at the wrong cam timing, unless the valve froze up for some reason.
I just replaced the head about 10 hours (run-time) ago. Last time I took it out I had a load noise from the top end and found that the first rocker tip actually fell off the valve and was banging on the cover.
The rod was bent and there is a 1/8 inch groove wore into the rocker stud.
Can the rocker stud be replaced while on the motor or is this pressed in and I'm SOL?
