havoc_squad
Thread starter- Joined
- Mar 5, 2011
- 741
Re: 3.0L rough idle issues
Well, go figure the carb is still a boat load of fail. After two lake tests after the carb rebuild professionally done. First test run getting the idle mixture dead on personally (me) on the water adjusting it under load at 600 rpm's per service manual procedure.
If the air mixture is correct, the boat idles just FINE. None of these symptoms I've investigated point to any other factor than flooding of the intake manifold.
Bone cold start is "slightly" easier than warm, but not a whole lot.
The carb instead now is flooding the intake after shutoff. Why I mention this, almost every time to get it started, I have to open the throttle full for about 7 seconds before it catches. Every once in a while, I get fortunate and it doesn't take much.
Then when I pull it back after it catches and gets the engine going, it wants to sufficate like someone with an Asthma attack when I pull it back to idle.
Exact symptoms:
Takes WAY too much throttle to get it started, hot or cold
Has a tendancy to kill itself in idle after near or at operating temperature after a long run or extended idling.
After shutdown, and a quick restart, it takes full throttle to coax it to start. (Flooding behavior)
Is there any good companies for a high quality remanufacturered Mercarb for the 1991-1993 Mercruiser 3.0L 2bbl carb? Preferrably with a real waranty worth more than the paper its printed on.
Exact symptoms:
