enginesilo
Thread starter- Joined
- Jun 9, 2008
- 355
Since I purchased my boat used over 5 years ago the temp gauge once up to running temp reads in the 190 range. Yes, I know that is too hot and it should be more in the 170+/- range. When I first bought the boat I checked the temperature with an infrared thermometer and it read in the 170 range but I remember the temp changing drastically based on where I was shooting the gun (At the thermostat housing vs other areas). I figured it was probably a sensor or gauge issue so I didn't change anything and the boat has been fine for many years.
My boat this season ran great at the start of the season but I have lost a few hundred RPM's recently. So I'm going through the list of possible things it could be and I'm circling back around to the temp. Should I replace the thermostat with a new 160 thermostat? Is the thermostat and easy install by removing the thermostat housing screws and just swapping the thermostat and gaskets.
I've never heard a buzzer alarm, but I've also never looked hard enough to see if there is a buzzer installed. Does SeaRay usually install buzzers in mid 2000 boats as a standard? Would the buzzer be tucked under the dash somewhere if I look below?
I'm not sure if this is the fix to the issue I am having right now, or if it has been an existing issue and has done damage, but figure it can't hurt to change the thermostat.
Any tips appreciated.
