First Id like to say I have a member for a little while now and have been searching this subject since Day1...
I am by any means no expert on boats but have a decent knowledge with Car/Truck motors and as much searching as I have done on here I had to post for myself instead of basing my problems off everyone elses.
So my Story...
I bought a boat the end of last year from an older man just trying to get rid of it after sitting for 2 years.
1988 16.5' Glassport
3.0 Mercruiser
Ran great in the driveway (of course) and actually ran great the first couple times I took it out, hitting the 4200-4600 RPM mark no problem.
After a while it started cutting out around 1900 RPMs and if I could feather the throttle through, it would pick back up and run fine. Then it slowly started to get worse, and then would only top out around 3900/4000 RPM mark. I searched this and other sites like crazy and replaced a lot.
I replaced:
Plugs
All the filters (separator, fuel pump, carb)
Cap
Rotor
Points/condenser
Set timing
I had the carb rebuilt, and the float had a gash in the side, so I thought maybe it was flooding since around 1900 is a pretty average range when the bow is up just before plane.
The guy I bought it from included every receipt and all the manuals for the boat so I have been doing lots of reading and I just can't figure it out. He replaced the fuel pump which would be about 3 years ago now, so that wasn't really on my list of priorities.
My fuel gauge does not work, so I wasn't sure if a sending unit would cause this? And I have also been told, that through the years, the fuel line coming from the tank gets old and can collapse. At this point I am open to anything, Money is a little tight at the moment but hopefully in a couple weeks I can try a new pump, but I still don't think that is the problem, but I am just trying to scratch off any possibilities. In the meantime though, I am just trying to think of any easy, cheap or stupid fixes I may have overlooked.
Any help would be greatly appreciated. Thank you in advance.
Tom
So my Story...
3.0 Mercruiser
I replaced:
Plugs
Cap
Rotor
Points/condenser
Set timing
Tom
