Dremmick1985
Thread starter- Joined
- May 12, 2020
- 38
I was checking base timing by starting engine and bringing up to operating temp then jumper the 2 white dist wires together and bypass the shift interrupt wires. After timing was set I reconnected shift interrupt wire and removed jumper from distributor. The engine would not come out of base timing mode, which in the past it would.
