3.0LX Audio Warning System Components
BeeEl
Can anyone tell me where the normal water temperature sender is? I am wondering if that is it on the bottom portion of the thermostat housing.
I can't seem to find the water temperature switch, the oil pressure switch, and the drive unit oil level bottle. I am pretty sure that's why I have some wires up there disconnected. Is this a deal breaker for you guys on here? It seems to me that would take out a possible false reading and keep you from being stranded. Your thoughts?
Thanks,
BL
Bt Doctur
Re: 3.0LX Audio Warning System Components
Are you positive it came with an alarm system? hi-temp is in the therm housing, low oil should be T`d at the oil pressure sender ,
Res bottle is kinda hard to miss.
Thanks,
BL
Ayuh,... Welcome Aboard,... Deal breaker,..??
It's 1 more thing to go Wrong,... actually 3,...
Ground out the wire end, 'n see if you've even got the buzzer,...
