3.0LX fluid question
victorc1
I looked in the manuals but I can't find, what type of gear oil uses a Mercruiser Alphaone Gen II and what type of liquid does the power trim motor use?
victorc1
Re: 3.0LX fluid question
To be more specific, what weight of oil does the sterndrive use, ex. 75-90, 85-90?
Also the trim, does it use transmission fluid or oil, or can it use both, right now it has transmission fluid.
JWebber
The gear lube from Merc. is 75 90. And as far as trim fluid you want to use one single type, don't mix diffrent fluid types. So suck out all old fluid and use only one type. It's oil, with a die in it. Use a cheap turkey baster to suck out old fluid from tank and purse lines etc..
victorc1
The previous owner told me he used transmission fluid, I checked the manual but can't find if it uses atf or oil, its a 1995 Alphaone Gen II. Thanks for the info on the oil weight.
JWebber
People have used ATF, but so thin it might leak from areas, so just use trim fluid.
victorc1
Okay, thanks for the help.
