3.3 hp carb help needed!
aaronvan
Hey guy's,I just bought a 2002 Mariner 3.3hp(the one with the nutrel and forward gears)It start's and idel's fine but as soon as I touch the throtle,it bog's out and die's then wont start again and leaks out of the bowl.
I was thinking that the float may be stuck,but if it was stuck it wouldnt start fine and idol,would it?
Any advise would be great.
Thanks
Aaron
alana
Re: 3.3 hp carb help needed!
leaks out of bowl.............. needle valve stuck. give the bowl a tap with a scewdriver handle to reseat valve, see if that stops the leak .
jimlad
Welcome aaronvan
I had similar problem give carb a good overhaul actually take it apart and clean everything and fuel lines as well
jimlad
aaronvan
I just took the carb off,and yes the needle valve was sticking,I cleaned the float and bowl.The needle valve was a little gummed up so I cleaned it up.One more question,What problem's will I run into if I don't run a fuel valve(petcock)?My motor doese not have one because the fellow that owned it before me used a external tank with it.
Thanks
Aaron
Silvertip
Look at the other post you made on this topic.
