frankttaylor
Thread starter- Joined
- Apr 3, 2012
- 100
Re: 3.7 Black Smoke - Exhaust issue (I think) - Boat Ramp Hell
Thanks. I will read through this.
Most all electric automatic chokes have a simple adjustment. You rotate the bimetallic heater coil housing CW or CCW to get the desired adjustment.
rotating too far in either direction will either make the choke operate all the time or not at all.
Here's an example with a picture of an electric automatic choke similar to yours. http://allcarbs.com/tech.php
The carb might not be the same or similar but the choke adjustment is the same.
If you do adjust the choke "out of the picture" ensure that you insulate the choke heater wire so it cannot touch anything.
It's powered all the time and will have 12v on it. tape it over or put some heat shrink tubing over the connector etc, to insulate it.
