Wayne in MO
- Joined
- Aug 1, 2010
- 9
First time boat owner (purchased late last year), 1989 Celebrity w/ 3.7 mercruiser 165 HP. After running for about 30 minutes, it starts backfiring and popping through the carb. Once it dies, I can restart, and it will idle, but once I put in gear, bogs down and dies. I have replaced fuel with 100 octane, have put heat in the fuel to eliminate water, replaced distributor cap and rotor. I thought it was the electronic ignition kit that I put in, took back out and put points back in, and still get the same thing. I have replaced plugs, plug wires, and coil. Mechanics don't run it long enough for this to happen, and say they're not sure.
Any thing else I need to look at, or any suggestions would be greatly appreciated.
