ericcarr2000
Ensign
Thread starter- Joined
- Mar 19, 2010
- 903
Ok, I have been trying to track down this mysterious ticking noise for quite some time now. It is only evident from idle to about 1000 RPM's. When you hit the 1000 RPM mark it goes away, at least you cant hear it anyways. You back off the throttle and there it is again. Ive tried to re-torque the valves down to the 24 ft. lb. mark, i've replaced all the lifters with new ones and the thing is still there. Ive had a few people say that a carb running too lean could be the cause, or maybe even timing being a tad bit out of adjustment. I've checked the timing and it is dead on at the 6 degrees BTDC mark. Any suggestions on this one here would be greatly appreciated. Please view the video ive attached,
3.7 mercruiser ticking - YouTube
