3.7 showing me no love. I think the spark has left our relationship
frankttaylor
All,
OK so the boat ran great last summer. I replaced wires, plugs, points, condenser, cab and rotor. I winterized it per the owners manual and upon starting for the new season it just will not fire. I am getting plenty of fuel but there is no spark at the points. The points look essentially new so I doubt that is the problem. I had the coil tested and he said without the actual specs it was hard to say if it is bad or not. I have have 12 volts to the coil and the ground is good. I am not thrilled at throwing 50 bucks at a coil if that isn't the problem. Thoughts?
1990 Blue Water
3.7L Mercruiser
Thanks,
Frank
:blue:
Re: 3.7 showing me no love. I think the spark has left our relationship
Ayuh,... Is there voltage to the points when they're open,..??
Is the other side of the points properly grounded,..??
If so, change the points...
It's the function of the points, to fire the coil...
frankttaylor
OK I guess I need to take an internal combustion 101 class. How do I check the voltage at the points and the ground? Thanks for your help!
Oshkosh1
Ensign
If it ran prior to the new ignition components I HIGHLY doubt the coil just "went" by itself in a static state.
I'm sure it's just a matter of a connection somewhere to chase down.
A DVOM will be crucial in finding the weak link here.
Just not sure about the wording of the post...you say that you "replaced" the points, then say they look "essentially new". You bought old points???
They're probably $7 new.
Make sure the point gap is set, then confirm the dwell with a meter. Check static and running when you time it.
frankttaylor
I bought new points last summer. Ran the boat a few times o when I say essentially new that is they are not "brand new"" any longer. Sorry for the confusion. I do have a meter. We did check the gap also. We should be able to see spark through the points when the engine is being cranked and the cap and rotor are removed correct?
Ayuh,... dependin' on the level of lighting...
points tend to glaze over, from Non-use... Change 'em...
frankttaylor
Should I change the condenser also?
Oshkosh1
Ensign
Yes...you'll also hear the "snap"...
Take a piece of cardboard and run it through the gap to clean off the new points. I did this to a 40 y/o snowmobile that was only firing on one cylinder with the original points sitting in a barn since 1988. They were a PITA to replace(unlike auto/marine) so I started with "cleaning" them. STILL running fine!
I can't see them corroding in that short of time unless they were in a very moist enviroment.
Oshkosh1
Ensign
If no result from cleaning them and you still feel your new points have glazed over in such a short time, AND feel the need to buy new(again), then yes, get both...just to be sure.
frankttaylor
Well I used a couple of those moisture removal "pots" but still had a lot iof mildew and the hoses on the motor have mold or mildew on them. Maybe there is moisture in there to corrode although there didn't seem to be a any evidence of moisture in the cap.
Oshkosh1
Ensign
That's what I consider "very" moist!
Still...try the cardboard to clean them off. If it works, great...you can decide whether they are bad enough to replace. If not, get new and give them a shot. It may just be a little soft build up on the contact point.
Oshkosh1
Ensign
Lol!
Saw your location...You're on the west side of the Cascades...home of the infamous "black mold". I was stationed in the Puget Sound area for a decade and know how wet the winters are, so corrosion is more a probability than possibility!
stonyloam
Here you go LOL: The coil is simply a transformer that steps up voltage from low (12V) to high (20,000V). Here is how it works: A (step up) transformer has two coils, a primary with few windings and a secondary with many windings. With the ignition on voltage (12) is applied to the coil + . When the points close current flows through the primary to ground (from the coil-) through the closed points and builds up a electromagnetic field. When the points open the current stops and the field collapses and generates a voltage in the secondary windings. Because the secondary winding has many many more turns in the winding the voltage that is generated is much higher. That secondary winding is connected to the center coil wire, and the voltage is transmitted to the center of the distributor cap, flows down into the rotor and jumps across to whichever sparkplug wire it is pointing to at the time, through the wire to the plug and jumps the plug gap (sparks) to ground. So you can test your points and coil by removing the cap and rotor, remove the center wire from the cap and place it close (1/4 inch or so) from bare metal on the block, put a piece of insulating material between the points, turn on the ignition and with a short piece of insulated wire quickly jumper from one side of the points to the other. You should get a spark from the coil wire every time you REMOVE the wire. If you do, your coil is good and your points are bad. Change them. As for the condenser, cange it if you like. Good luck.
bfjou812
There should be a resistance wire that runs from the choke to the coil. Check that ,if it is bad the coil will not get the correct voltage. I've had this happen twice to me and am considering replacing it with a ballast resistor.
FreeBeeTony
EXCELLENT explaination!!
frankttaylor
Carboard trick worked great! Runs like a top. Thanks again!
$300boat
I'm assuming, that if I did this and did not get a spark, the coil is bad?
stonyloam
Chances are that is the case.
