ericcarr2000
Ensign
Thread starter- Joined
- Mar 19, 2010
- 903
Ok I recently had thought that I had a fresh lifter tick in my 3.7 mercruiser motor. I replaced all of the lifters with new ones and the tick can still be heard. The funny thing is you don't hear it when you first start the motor up or upon acceleration. Basically the only time you hear it is from idle to just above 1000 RPM's. Then that's when it seems to go away. The motor is a blueprinted 3.7 mercruiser that has only 100 hours on it. Is there anyone out there that can give some suggestion into this. I did a compression check on the cylinders and they all seem to be between 110 and 120 PSI.
Thanks
Thanks
