grady86
Thread starter- Joined
- Feb 19, 2014
- 32
I have a 1990 Bluewater cuddy cabin with a 3.7L alpha one I/O. The last time I had it on the water was approximately 6-ish months ago. Everything would run fine mid to full throttle, but once I brought it down to idle or neutral, the motor would slowly sputter and die. After trying to turn it over unsuccessfully a few times, I let it sit for about 30 minutes and then attempted again. It finally fired up and I quickly motored back to the marina. Once there, it died again in the same manner as before, and I had to get a tow into the pier.
Here is what I did to try and solve the problem:
Replaced spark plugs, changed motor oil, changed oil filter, changed fuel filter, added ethanol treatment to fuel tank (I keep the fuel tank completely full when storing to prevent condensation). At the shop, with mouse ears connected, it seemed to be running slightly better, although it still died a couple of times while idling. After it was "warmed up," it was running like it should at idle.
Took it to the water today to give a test run and didn't even get it off the trailer because it wouldn't fire up. Any help would be appreciated... have to get this thing up in time for crab season!
