3.7L Temp gauge question
mdlee
I don't trust the electronic temp gauges on my Mercruiser 3.7L so I added a mechanical gauge. I put the thermo unit in an empty plugged hole right beside the thermostat on the exhaust manifold. My question is will this give me a good reading, or do I need put the thermo unit in the block?
rebars1
Re: 3.7L Temp gauge question
If that hole was intended for a temperature alarm sensor, you should be OK. Maybe have both devices hooked up (with two guages) and compare the temps until you are confident that it works.
Big Boat Bay Buster
Thats exactly what I did with my 470. I had a mechanical temp gauge laying around for test purposes and put it just where you did. This confirmed that my electric gauge was off. Mechanical gauges are the most accurate. I replaced both the sending unit and gauge(electrical) since they were 25 years old. All was good after that
Chris
mdlee
Thanks Fellas.. It seems to be working well.. I feel better knowing someone has done the same thing. And sure enugh the electronic gauge was off.. the motor runs colder than the electronic gauge reads. I just instaled a new riser.. I think all is well.
