Randy stoner
Thread starter- Joined
- Aug 20, 2002
- 78
I have a 1991 sunbird corsica 175 Cobra with a brand spanking new 140 hp Chevy four cylinder engine. Out drive is total rebuild as well. The prop that originally came with this boat/motor is a stainless 391290 15 x 17. I also have a stainless 48-821154 17 high five. The motor like i said is brand new and has maybe 8 hours running time on it since i was installed last summer. 5 hour break in at the marina who installed it and about 3 hours of my running since. By GPS the boat with several people in it will run 35 mph every time. The big 3 blade prop however will only bring my rpms up to about 4200 yet the high five with 5 blades will run at 4700 rpm. Both speeds by GPS is 35-36 mph. The boat weighs 2000 lbs dry. I have two questions and or observations. Ideally you want the motor to run up to and or near its proper WOT rpm so why is the five blade doing that where as the original prop isnt? Secondly, i have a four blade aluminum 48-83485 c18 prop that I have yet to try. The big three blade weighs far more than the high five and of course the 4 blade alluminum will weigh half of that. Im thinking since the 3 blade is not allowing the motor to run near its proper rpm I should be using the high five even though every where i read, the high five should be too much for that motor. I know some will chime in and say their boat with similar configuration goes a whole lot faster and yes that probably true, how ever no two hulls are the same so im not so much concerned that way but i dont want to harm the motor by lugging it down.
Randy.
P.S. Be safe and thankyou
Randy.
