Dale Penkala
Thread starter- Joined
- May 2, 2010
- 7
Hello everyone! I'm new this forum but have been reading the posts on props here. Decided to join as there seems to be very knowledgable people here. I've got a question about a prop for my boat. Here is what I have.
1997 Larson Sei 206 with a 4.3 LX GEN+ Currently with the stock prop that is a aluminum 3 blade 14.25x21. In all honest I'm quite happy with the performance of the boat but I kinda thought if I could get a bit more top end with the boat that wouldn't cause any more wear and tear on the motor then that would be great. I've talked with many people about going to just a stainless prop to get more performance some say yes some say no 1 says it depends on your current situation and setup of the boat. Here is what I can tell you about my RPMS etc...
Manufactures recommended WOT 4400 - 4800 RPM.
Currently set not to go over 4900 r's.
I can reach this without any problems 100% of the times in fact when things are right and I run higher octane gas you can feel the motor kick itself back.
I talked to Julie here at iboats sales and she had suggested to stay with an aluminum prop but go to a 4 blade. That would give me more top end speed and if I really wanted to make a change than go with a 4 blade 23 pitch prop seeing as though I have the RPM range as going to a 23 pitch would drop my RPM's about 200.
I'm hoping someone out there has had the same thoughs and more importantly made the change to give me advise as to what to do.
Any advise is greatly welcomed! Thanks in advance!
Dale
Dale
