3-cylinder with Rod Through Case
JDusza
I am being asked to help rebuild a 3-cyl, 80 hp, oil injected engine that put a connecting rod through the case. I do not yet have the serial number, so, I don't know year. I will get that soon.
Here's what puzzles me: I can't really see rebuilding and re-using some of the parts from the failed engine. If this was lost to an overheat condition, I would expect the crankshaft to have changed its heat-treat characteristics locally. I would expect the crank to have lost its strength locally and become brittle. And then, there's the question of the other components; piston (and rings), are they cracked?; bearings, what is the integrity of the remaining cylinders, etc... Perhaps you'd get a year or maybe two out of it before it fails with an over-stressed component. I would be more inclined to replace the entire power head. Of course, we still haven't discussed the reason for the original over-heat...sigh...
Any advice? Thanks.
J
Faztbullet
You will never get the engine that hot to change the metallurgy of crank as they weld the up and grind them down on a rebuilt crank. You will need to replace the pistons as the ring locating pins will likely be loosed. If the rods are blued replace them also along with all bearings.
JDusza
And, the hits just keep on coming!
Thank you.
