Evinrookie
Thread starter- Joined
- Aug 20, 2007
- 100
Changing the gear lube in my newly purchased 67 Evinrude 80Hp, I found 3 issues.
1. More water than oil came out when I drained it. This is normal right?....No?....Didn't think so. The gaskets seem to be in good shape. Are there any common places that are prone to leaking? The prop has a little play in it before it feels like it's catching. Is this normal? How can I check for where the leak might be?
2. There is a notch where the lower gear housing meets the upper gear housing (Picture 1). Is this supposed to be there or did somebody pry too hard with a screwdriver?
3. There is a little hole below one of the bolts on the upper gearcase housing. It has a slow leak but it is not gearcase lube(Pictures 2 & 3). It appears to be unburnt 2-cycle. Would this little hole be letting water into the lower unit? Does this look like a job for JB Weld?
