3.o omc
wht89gt
I have a 1987 bayliner capri pulled the motor and #3 piston is toast and rod is pretty ugly also number 4 feels bound at the wrist pin does anyone have 2 pistons connecting rods and rod cap extra they could sell me? #3 piston is real ate up on left side not sure if detonation or water looks pitted to heck and back and real brittle looking still hard but just looks crumbly? Oh its a 3.0 i know it says it in the title but...
ken_23434
Re: 3.o omc
I am pretty sure the rods in the 3.0 are the same as used in the 5.7's. Knowing that, you might have pretty good luck finding rods at the local machine shop since the GM 5.7 is pretty common. I am not sure on the pistons, though. Have you priced new ones? The website hosting this forum sells parts.
wht89gt
Re: 3.o omc
How sure are ya about those rods that is some pretty helpful news it make it alot easier if what youre sayin is true. I was just looking to find pistons with rods together so i dont have to get the wrist pins installed. I read somewhere that the pistons are just a hair larger. I need to go just a lil bit larger than stock on my rings got a little small scrape in 3 any clue where to get oversized rings? Thanks for the help all i am trying to get this thing in the water got a descent deal and the motor is not too old of a reman but...
ken_23434
Re: 3.o omc
When I first got my boat, the motor was junk (along with most everything else).
I spent a long time at a local machine shop, and they were really helpful looking up specs for the engine trying to find replacement parts. I was reluctant to use something other than "the correct parts", but they were insisting that all the measurements for this part or that part were the same as the 350. Right now, I just cannot remmeber the specifics.
I would start off by trying to see what info you can get from the GM website. They still make the 3.0 (I think). I had previously found drawings and some tech info about dimensions. I know the outside dimensions specifically where there (clearances, mounting locations etc), but I think the bore, stroke, etc. were also listed. Otherwise, I might check for parts listed for "rebuild kits" and see if the same connecting rod is also sold for another application. I would check with a non-marine specific site, like TRW or someone else who deals a lot with engine rebuild kits. If the TRW rebuild kit for a marine 3.0 uses the same piston as some rebuild kit for a GM 350, then you have your answer. Now, Marine applications probably use forged or hyper-eutectic pistons and not cast ones (cast are the cheapest).
Or, you can hope to find a machine shop that is willing to research for you.
Re: 3.o omc
Ayuh,... But the Rods in a V-block are different than an Inline motor....
You don't seem to have a Solid grasp of how motors are Rebuilt....
Your motor needs to go to a Machine Shop for evaluation,...
The path you're going down now will only lead to an Extremely Short lived motor....
If it runs at All...
wht89gt
Re: 3.o omc
I understand that machining the block down and punching it 30 then spin the crank 10 and put in 10 over bearings and have it balanced but i dont really have the 800 plus labor to do this right now. Just looking for a fix.
Re: 3.o omc
Ayuh,... That's the Problem,... Your explanation is the Only Fix...
There are no Oversized anythings but the Standard Oversizes(rings, etc.)....
A Scratched bore is Junk, unless remachined...
350s might have the Same Bore,+ stroke,.. but the pistons,+ rods are Different....
wht89gt
Re: 3.o omc
You are correct sir just got off the phone with a machine shop i didnt even know was around here!
Re: 3.o omc
Ayuh,... Don't go gettin' all formal or nothin' now,... We're just startin' to get somewhere....
Welcome Aboard....;)
