Just for fun
Thread starter- Joined
- Aug 31, 2008
- 19
I have a '99 Chapparal 180 LE 4.3 Alpha one Gen two. The prop was damaged when I bought it so I tried 3 different props to find the right one. I used one of the prop calculation tables on one of the websites and it recommended a 17", 19", or 23" depending on use and number of people in the boat. I bought a 19" and 21" thinking the 23" would only be good for a light load.
The 19" aluminum Hustler maxed out the rpm at 4800. The 21" aluminum Hustler also maxed out the rpm at 4800. According to Mercury, the max RPM should be 4400-4800. I was looking for about 4700 to be sure i wasn't on the rev limiter. I wanted to try a 23" so I made a deal on a 23" Mercury Laser II stainess prop. After driving 70 miles to get it, it turned out to be a 25" prop. The price was good ($80), it looked like new and it came with the hub kit so I bought it anyway. I tried it today, here are the results compared to the 21" aluminum.
The 21" ran 30 mph at 3000 rpm. Max was 53 mph speedo, 51-52 GPS at 4800 rpm. Fuel tank was almost empty (3 gallons left at fillup)
The 25" ran 35 mph at 3000 rpm, max was 58 mph speedo, didn't have the GPS today, probably 56 mph at 4600 rpm. The 21 gallon gas tank was full.
I did notice it was not as quick to get on the step, but not too bad, and was somewhat surprised at the speed I was getting. I didn't know it would go that fast.... not that I would stay that fast for very long. I was running it to see the rpm to evaluate the prop, not to see how fast I could get....that's my story and I'm sticking to it.... it was fun though...
My questions for someone much more experienced or wiser than myself:
Would this be a good prop for a cruise up the intercoastal where I would probably be running at about 3000 rpm? It does push the boat 5 mph faster at the same rpm setting. Is is straining the engine with the higher pitch? Would it be more economical on fuel or would the engine load cancel it out?
Would I be better with a 23"? I'm surprised the 25" did so well, that's a steep pitch for a 4.3, although I do have a 1.81 ratio outdrive. Is the 1.81 instead if 1.6 why it seems to work out?
Should I sell it and get a 23"? I don't want to stress anything with the steeper pitch.
I don't intend to use the 25" for watersports, I have the 19" and 21" for that.
